TPM Obi-Wan Kenobi belt replica
Great looking belt! You made it look easy to make. I know you said the wider belt is 2.5". What size is the inner belt?
As an aside, is it Ok for shorter people to go with a belt that is only 1.5" or 2"?
Saberbelt has some very cool buckles. There's one I really like but it's not available in the finish I wanted.
I mentioned in the first paragraph of the initial post that the main wide belt is 2.5" and narrower top belt is 0.5". I suppose a shorter person could scale the dimensions down but I would suggest making sure the relative proportions of everything would need to be maintained to still capture the right look of these belts.
How far appart are the studs nearest to the buckle?
This is what I came up with as far as the layout of the buckle and button studs. I hope that helps!
