superrune
Hi everyone,
Sorry to post a non-replica item in the forums, but my Star Wars models tend to be all virtual these days. But I've got this problem on a batch of resin models that I have been painting the last week, and it seems to me that you guys would be the best help on this.
I've printed out a couple of 3D models at Shapeways that I have molded in silicone. After that I cast out a bunch of resin copies using Smooth-On 305. So far so good, everything looks excellent. My tiny problem appeared as I tried to paint the resin models.
When spraying the resin, either with acrylic car-paint, primer or synthetic paint (montana spray cans), I get these really tiny pinholes along corners of the resin. They are quite small, but they stay after each coat, getting deeper and darker after each layer is painted on.
Here's a photo where you can see them:
I haven't used any kind of release agent on these models. And while the models are smooth to the touch, they are not oily or wet in any way. Unfortunately, I'm spraying outside, in quite cold weather. But the paint is kept indoors, and the models are drying indoors as well. Anyway, I'm also painting some metal objects at the same time, and they don't have the problem, which makes me think it might be the resin. The primer sticks really good to the resin though, so it's not as if the surface is impossible to paint or anything.
Has anyone here had this problem when painting plastic or resin? Any tips to what I should try to do?
Thanks!
Thanks!
