Dei
Member
You'd normally build the foam up first by stacking it together. Glue everything together by using shoe glue/super glue, then cut down 2 levels into the foam with a cutting knife/blade. This is where you'll glue your shoe! It should fit snugly into the hole that you've just cut out. Basically, everything after that is carving the foam away and disguising it under the armor
