My recommendation is to make a paper pattern that fits you well and then lay it on the vest (or vice-versa) and you will see what to cut away. The pieces you cut away get added back on to go around the sides, if memory serves. Remember, it is pretty short, top to bottom. It ends where the top of the battle belt begins. It does not go under the battle belt.
Hope this helps,
Steve
Sent from my iPad using Tapatalk HD
I really can't remember for sure. I ended up with a male snap at each shoulder, which comes in handy later, if that helps to sort out which part goes where. You can always add the snaps so it is not critical, but that fact might help you figure out which part goes where. The bottom line is that we are really just using the vest as a source of fabric and bias tape that are the right color and weight. Leave the pieces as big as possible and move them around until it looks right (and try to end up with a male snap at each shoulder).
Sorry I can't do better but there is no way to tell by looking at the vest now.
Good luck!
Steve
