Limited Run TAKING PAYMENTS Machined X men origins claws! RUN IS A GO!!!!!
Re: Russrep Machined X men origins claws! RUN IS A GO!!!!!
Doesn't make sense to have them squred off,don't look "authentic". I will definately sharpen them. Russ can you show a few pics of close up of tip of blades
Hi guys no those are how the claws will be , I have done them like that so they get through customs etc
If you want to sharpen them you can but I do not advise it,
If they were sharp they would not make it out the uk
Russ
That makes sense, I guess. But, you can't even just round off the tips? I didn't expect them to be sharp, but, c'mon.
Will there be anyway of having the wires come out from the back of the blades instead of the bottom of the blades? That way the wires are hidden instead of visible when they are gripped?
Hi the claws are all machined and holes drilled, If you are not happy with how they have turned out please pm me I can send you a refund, These were very tricky to machine and hold, I did not have any drawings to go by,
when I say I would'nt advise against sharpening them its because they will be very sharpe and dangerous!!
Russ
Russ,
I sent a PM asking for a refund.
I don't have a problem with accuracy issues and I have never complained about the time the project has taken. However, the visible wires are a problem. If they don't look convincing (as if the really were coming out of the fist rather than an item being held) I just do not see the point.
Sorry. :(
pm sent for a refund
It pains me to do this..... PM'ed for a refund. Sorry Russ. I know you have a lot of time in on these.
Issues for me are , The wire look thick and hard to manipulate, I want to get the claws up to my skin. The wires are also look pre-bent The claws are shiny(I like), I don't think I could fix the ends to come to a point without making them look bad, also I don't I know anyone that could help me. There are to many thing that add up that take away from screen accurate. I really wanted a metal pair that were closer to screen accurate. With all the modification I would need to attempt if I kept them (not even sure if I could make them work how I want) I would need a lot lesser price to stay with these. If you are stuck with a lot of claws due to canceled orders and want to work out a lower price Russ, PM me.
Hi guys sure no problem I understand, I will get that sorted for you tomorrow.
The rods are clamped up by a screw which you can undo to bring them out or move them in, also the whole claws and palm all un screw.
Russ
PM sent for a refund.
It pains me to do this. Been looking forward to these for over two years now.. :(
And I know it's taken a lot of time and work to get these completed. But I was expecting a different product. Sorry.
Im just going to try some thing tomorrow and post a pic , I will get it done in the morning :)
Russ
The claws looks great I do hope there is a way to solve the wire part. if you can make it come out of the back that would be great.
Sounds promising Russ.. I might change my mind about the refund, depending on what 'that thing' is.. :)
Russ
I'm afraid I want a refund also.
Been waiting so long for these and not convinced on the screen used accuracy.
Can't hang in there anymore.
Russ
Ok, Forget the PM I sent for now, I will hold of on the refund and wait to see what you come up with :D. I really want these to work out. If you make the end look like the real claws, sharp looking and pointy that would be enough for me and you already addressed the ability to get the claws up to the skin. The ends don't have to be sharp, even the very end were it's to be pointed, you could slightly round the pointed end so that it would not break skin unless enough presser was used, that way they look screen accurate and are not dangerous. I don't think anyone wants sharp claws, just sharp looking claws.
I'm not sure what i want to do here. I've waited over 2 years for these "Screen Accurate Claws" but it doesn't look like thats what were getting.
I'm willing to wait and see what you have in store as well, but if they will be shipped with the squared ends, then I will not be interested
Same here. If there is some way to have the edges sharpened or at least rounded off so it looks screen accurate then I'm still in. They don't have to be razor-sharp.
Couldn't you do what you did with the Batman Arkham Asylum Batarangs? They look pointy but are actually blunt.
I'd like to see what you're planning on doing with them today first.
