Limited Run STIII Klingon Rifle Sling
jhusel
I'm very excited to announce this run. I am doing a run of Rifle Slings from STIII, for the Klingon Rifle. These slings are 3D Printed in dark gray rubber on a Formlabs SLA Printer, real leather for the strap, real spring, hand bent metal hardware, and real threaded rifle sling mounts
Option 1 - Sling Kit - (YOU will build it) - $75
This will consist of:
3 raw prints (you will need to clean up)
Spring (you'll need to adjust the length)
2 bent metal "rings"
2 pins to attach the "rings" to the rubber sling
2 pieces of leather cut to size (you'll need to drill holes for the rivets)
4 rivets (you'll need a rivet gun and install them)
2 threaded rifle sling mounts
Option 2 - Finished Sling (I will build it) - $100
A fully finished sling as you see in the photos (finished with pigment)
YOU will need to drill the holes in your Rifle and screw on the rifle mounts
PM for Payment details
Here is the sign up list. First come first served. The first batch will be 15, I'll do another if needed
1 - MustangGTR PAID
2 - Kertratz #2
3 - John Harrington #2
4 - Onigiri #2
5 - Onigiri #2
6 - Bill313 #2 PAID
7
8
9
10
11
12
13
14
15
