Sovereign Replicas Enterprise E WIP
DarthDuck
Received an SR Enterprise E to build complete with the kit's PE and recommended electronics. This should be a fun one and will hopefully come to represent the handsome ship which the Sovereign Replicas model can build into. There was a slight delay on my part since I had little choice but to add some additional work surface to the shop to give me some much needed elbow room! A little bit of running around to the local home improvement centers yielded 19 more linear feet of countertop with some supporting cabinets although the gaps in those will be filled in later.
Back to the excellent kit though!
Thank you gents. Me too.:cool
A very fast mockup of the components shows it will be around 42" tip to tail.
This is going to be fun to watch, Don.
Is this a commission or for yourself?
DD,
take it from one who knows...
find some way to make an internal armature. eventhough the fiberglass is light. My ship is a little more than 3 years old now and the nacelles are noticeably sagging.
find a way to join the pylons to each other. I had braced the pylons against the hull, but it is the fiberglass in the hull that is buckling.
If I had Richard's ear for one moment, I would ask him not to have split the secondary hull down the center, but split it top and bottom along the pylon-line
I can provide photos so you can see the trouble spots
I'll take some new pics. I first noticed after about a year, also I forgot to mention the point on the belly where the support rod goes thru is also sagging due to weight. eventhough I reinforced the inside with a heavy brass plate.
After I get thru some other builds, I may see if Richard will sell me some new decals, so I can brake it down and rebuild
Doing some preplanning on the lighting I used some very bright blue mini surface mount LEDs arranged in a row and then experimented with either clear tinted ("smoke") or some opaque "filters" at twelve volts and they were all too bright. I then switched to nine volts and also varied how close they were near the top. Some were taken with the lights at "mid nacelle" height while IMHO the better effects were from having the lights down at the bottom of the nacelle. All pictures were taken in a 'well lit' room without flash as you might normally view a displayed model.
Just goes to show how effective the fiberglas model is at passing light and how I will need to fine tune using the same LEDs to best effect.
