Really beautiful work! Well done. Ive been lurking on this project since it began, waiting silently for updates and being continuously impressed. You must be very proud!
Sent from my GT-I9100 using Tapatalk
This is the best one I've seen so far! Do you plan on doing the muscle undersuit?
Man do I want this suit, absolutely the best, too bad I can't afford it.
Thanks guys ... and heres this finished suit with cape ..... throw in all pics before i go off on my business trip .
Masked Rider -- Curious about something... I didn't notice it before, but when you do the shading for the yellow, are you also shading the red portion of the S? Wasn't sure if this was intentional or not.
For anyone interested, as far as I can tell, here are the new suit changes based on the new released photo:
-Smaller shield/emblem with new S design (similar to the stone S symbol from promos) with the red layer raised above the blue frame
-Gauntlets are now inter-woven with the base suit, not resting on top of it, and are strap like rather than solid
-Side ribbing is broken up into separate lines instead of being cast as one piece with the outer line turning at a sharp angle down towards the "belt"
-Square "buckle" with S
-Waist gold bands are slightly wider and have a sharp/angled edge, rather than coming to a point
-Top of boots are different (not a solid band, but rather two outer lines overlaying boot)
-Neck is slightly curved in between cape attachments rather than being straight across
Here's a high-quality version of the image:
http://i.imgur.com/Gbj6CRx.jpg
This high res image definitely helps!!
I didn't notice this before, but there's an "S" inside the square buckle. Kinda silly IMO!
Makes me wonder how they are going to pull off the Clark-to-Superman transformation. This suit does not seem to be easily hidden under daily wardrobe.
This would be a perfect opportunity to make Clark be an overweight guy.. he can wear a fat suit over the Kryptonian suit.. it would hide his identity easier too![]()
