Limited Run SNW Phaser "Big Damn Hero" Kit
Kokanee
As a Starfleet officer beaming down to planets and encountering dangerous adversaries such as Klingons and Gorn, having a high-quality, reliable phaser by your side is not just important—it is absolutely essential. The phaser is not merely a weapon; it is a tool that ensures the safety and protection of both the officer and potential allies, enabling them to navigate treacherous situations with confidence and efficiency.
This SNW Phaser “Big Damn Hero” Kit for the first time brings together everything you need in one box to assemble a static “hero edition” prop:
CNC Machined Parts:
  • Emitter Assembly (Aluminium)
  • P2 Side Dial Assembly (Aluminium)
  • Trigger (Aluminium)
  • P2 Fins (Aluminium)
  • P1 Setting Indicator Dial (Aluminium+Vacuformed clear dial cover)
  • P2 Stun/Kill Indicator (Aluminum+ Acrylic)
  • Selector Switch (Delrin)
  • P2 Studs (Aluminium+Brass)
Laser Cut Parts
  • P1 Crispy (Aluminium)
ABS Resin Printed Parts (Printed under license from LimeyBuilds):
  • P1 Body
  • P2 Body
  • P2 Handle
  • P2 Handle Base
  • Misc internal parts
No electronics are included in this kit, it is when built a STATIC prop. However, an electronics kit that was designed to be fully compatible with this one is releasing shortly.
Black Sea recommends Starchwreck Models and Props as well as AJ Catalano Designs for those looking to commission a complete build of this kit. We can even ship directly to them to save you the trouble.
If you would like a display stand for this prop, a limited number are also available
Orders go to production 05 August 23. Shipping date is no later than 30 September 23.
To order, please do so here: Black Sea Prop Shop
Was waiting for this :) - Just placed an order. Also sent you a message through your website.
Thank you to all orders so far!
As the Aug 4th date for closing the phaser order draws near, work is progressing on reviewing all the components and making some small tweaks for accuracy based on new reference material. So far, the indicator assembly has seen small changes (indicator light ring and button cap both stand approx 0.5mm proud vs flush in the first release) as well as the P2 lugs, which are 0.2mm thicker in diameter now.
This run closes the 4th of August, and orders can be placed at blackseaprops.com/shop
