Scratch built Captain Rex
stormtrooperguy
This project has been a long time running, and I don't know that I ever really posted here about it.
It was during Dragon*Con 2008, soon after having seen the Clone Wars movie, that I decided I wanted to make a Rex costume, and I wanted it to have the stylized Clone Wars CG look, rather than the AotC / RotS "realistic" style.
I'll start with the final product. These pics were taken yesterday, and represent my first time wearing the entire thing, all of my own construction:
The helmet has distant ties to a Hasbro voice changer clone helmet. I started with that, filled the seams / reshaped the face then molded / cast it.
I took a cast and cut it up / rebuilt pieces to get the CW v1 helmet. Then I did that twice more to get to where it is now. Each time with the full on silicone mold. Having never done this sort of thing before, I didn't really approach it the best way ;)
This was also my first time building armor like this from scratch. I learned a LOT as I went... If I knew then what I know now, this would have probably taken 1/2 as long!
The armor masters are all made from MDF and Bondo. I didn't want to have to sculpt / cast / pour a positive to form off of, so I made the originals out of something that I knew could take the heat/pressure.
I think I went through a 1/2 dozen 4'x8' sheets of 3/4" MDF, about that many smaller 2'x4' pieces (sometimes I had to pick up supplies when I didn't have my truck), and 8 gallons or so of Bondo.
Over the course of this project I bought a lot of tools. Band saw, a few sizes of belt sander, more clamps than I'd ever have imagined, and a LOT of nitrile gloves!
The whole project followed the same general formula:
  • Trace body part
  • draw armor around it for the desired look
  • slice up into 3/4" pieces
  • draw those pieces out onto the mdf
  • cut
  • glue
  • sand
  • coat in bondo / sand / recoat until happy
  • vac form
  • assemble
  • paint
It's been an interesting trip. Having now done the scratch built suit of armor, I have all new appreciation for how much effort goes into those kits that I used to take for granted.
Remind me never to do that again ;)
Very nicely done. That is an impressive piece of work. Kudos for getting it done in one year. It took me two.
If I may make one suggestion for ease of build, I use polyurethane foam rather than MDF. The process is the same: You block it out and sand it down to what you want. Except that the foam shapes effortlessly, as opposed to grinding the MDF. I also do not use Bondo for the same reason, elow grease. It take time and effort to sand. Rather, I use the (air-dry) glazing putty that comes in a tube. Why? Because if sands smooth effortlessly. You can vacuform right over it, and use the pull as a mold to pour plaster for a new stone buck.
You can also skip the glazing part, and vacuform right over the foam (preferrably 6#) and pour plaster, then give the buck a good sanding. Done.
I only suggest this as it would be a time (and elbow grease) saver. The result is the same.
What amazes me most about Brian is hearing him say" I don't know how to do this and Im not sure it will work." I met Brian because of the RPF and became a member of the 501st shortly after. This suit is killer in person. And he's not kidding, he's revised the suit and made subtle and not so subtle changes so many times, you have to look at comparison shots sometimes just to see the difference.
Of course this doesn't change the fact that he's Glenn Danzig short. And that I'm thrilled I can outrun him when he reads this.:lol
Thanks so much for sharing this! Awesome work! Also a neat new technique to make armor masters (perhaps even the armor itself!)
I know what you mean by "how much effort goes into those kits" very well. :)
