Happy New year all. This top post is a placeholder to preview the models and overview the designs while preparing a larger, and more cumulative post.
The short of it is this:
This model is based predominantly on reference from PropStore auction #373. After much review, and comparative analysis of the existing/ known ROTS hilts I believe it is “the belt hanger” seen on his arrival to Mustafar; and in the hallway with Bail Organa.
Ronin Sabers (who you may know as a reputable installer, YouTube reviewer, and hilt designer) and I got to talking about his initial modeling of this hilt last year and wound up going into very great depths of refinement. I’ll do some direct mirrors a bit later so we can discuss nuance.
We have a static version on deck using mixed media (chrome plated plastic / paintable plastic / aluminum / steel / brass / threaded rod/ and tension pins for clocking)
And we have an FX version on deck, where RoninSabers is currently filling that out with his chassis design.
Quick features on FX:
-7/8 blade only
-Brass and copper neck collars and solid emitter with integral neck bolt/ core.
-Clockable booster and pommel via heavy duty internal slip collars.
-Tactile dual box switches.
-Fully removable chassis/ core
To reiterate : I plan to add more details and photos, but will be making some additional posts below as placeholders for that discussion.
Pricing:
Our Civilized Hero iterations are as follows:
FX KIT- $375
- clockable booster and pommel.
- primarily carbon steel construction
- copper and brass neck sleeves
- spring loaded plungers under clamp
- accurate clamp card material
- asymmetric grenade valleys and grenade vertical milling
- our carbon steel covertec
This would include:
1x Allen key for blade retention screw.
shipped in official Civilized Hero packaging.
STATIC KIT- $250
This will be a non installable version representative of the materials and construction of the original prop including…
- vacuum metalized chrome plastic emitter, box, and body
- stainless steel emitter base and greeblie
- copper neck and greeblie
- brass windvane
- plastic grenade and booster
(delrin likely pending sample finish)
- correct material clampcard
- 7075 aluminum pommel
- clocking pins
- threaded rod for assembly
- our steel replica covertec
BUNDLE KIT - $600
This will be for those that want to make one purchase that includes both the FX and Static hilt.
This would include:
1x main FX hilt (as described above)
1x Main static hilt (as described above)
1x Allen key for FX blade retention screw
Both hilts shipped in the single box, Civilized Hero packaging
-7/8 blade only
Pricing:
FX KIT- $375
This would include:
STATIC KIT- $250
- brass windvane
- clocking pins
BUNDLE KIT - $600
This would include:
