ROTJ Solo blaster scope mount screws, and washers?
jason1976
Ok, so I have an CE ROTJ Solo blaster scope mount, and wall the mount itself, is outstanding, the screws, and finishing washers that come with it, are far smaller then the ones on the real gun, and the washers don't match the style of the ones on the real one either.
The washers on the real prop go to edge all around them on the rounded ends of the scope, but mine set in quite a bit. And, the ones I have are rounded on top, but the the ones on the really prop have flat tops. The ones I have set flush with the top of the screws so there's no way to file them flat with out messing up the screws.
So what should I use for the washer? (size, style, etc.) and should I move up a size on the the screw, or is it ok? (the ones I have now, and the whole in the mount for them, is about 1/8" )
I really want to get this project doen, so any help would be GREAT.
Thanks
jason
I´m not at home right now but you´re comparing ifferent ROTJ blasters, so there ARE differences in the mounts/ washers.
I´m sure somebody will chime in with pics of the stembridge, vs. alternate, vs. hero ROTJ Solo blaster ;)
In the meantime...search for ROTJ blaster, there was great thread, started by me IIRC.
Markus
No, actualy I'm just talking about the MOM (black grip) version of the blaster. I'm trying to get the screws, and the weird little bits under them, on the scope mount, correct, but I will see if I can find your thread. :)
