Robin costume
Tyler Brush
Hello I'm in the process of building a robin costume and I need help how how I can put armour like on this pic
The foam method is pretty popular, using EVA foam mats to shape armor plating, as they can be cut easily and bent into shapes with a heat gun or hair dryer. Alternatively, you could sculpt the armor out of clay over a manikin and then take a mold of that and cast it out of latex.
Do a little more searching around the forum, there's a wealth of knowledge here on these two methods, as well as pepakura and plastic armor plating (which is what I'm into). Good luck on your build!
Thanks
I wanna do the tim drake from the animated series robin but I want it to be more realistic
If you would give me you email just in case I need more help on the project
