I've never heard of anyone doing this, but I won't call it my own technique
because I'm sure someone out there has thought of this lol
I bought a paint pressure pot at harbor freight for around $80.00 US and since
I use a lot of silicone, bubbles are a problem. So one day for the hell of it I
took my Air compressor (cheap one) and hooked it up to the pressure pot
and got it ready for casting, I sat for a momment and thought " I wonder
if applying pressure to the silicone would remove the bubbles like a vacuum
chamber would" So I tried it. I got my piece ready, mixed up the silicone, and
popped it into the pressure pot and set the pressure to about 50 PSI and left
it for the time needed for the Silicone to cure.... After the nessesary time had
passed I removed the part from the silicone and cut it down the middle with
an exacto knife to see what the results were.... I was very pleasantly surprised
to see that not only did the silicone capture the detail perfect, but there
wasn't one bubble in the mold. Ever since that day this has been the
technique I use since it's been full proof, plus it's a hell of a lot cheaper then
buying a vacuum tank
Just a little warning though.... Usually Silicone needs many hours to cure and
leaving pressure in a tank can be very dangerous if the welds, fittings,
or any other part of the pot is faulty.. I always check everything when using
my pressure pot and when I do pressure mold silicone, I place the pot far
away from anything in the rare case that it my go boom!
I'm not trying to scare anyone lol
because you face the same risks
when you pressure cast. I just wanted to add the little warning to keep you
guys safe
