Removing wood burning in plywood
Gixxerfool
I thought of a quick prop I want to do. I was inspired by the Man Crate I got for Christmas. The crate has me over half way there with only emptying it. It will be getting a light coat of white on the exterior. I need a way to cover the branding on the sides. It's plywood and I would hate to just build another. It defeats the purpose of this. Thanks in advance.
Try Drano (you know the product used to unplug pipes) Test it on a part of the box. Add a little water, wear goggles, heavy rubber gloves and use it outside (the fumes are nasty).
You can also mix it with a whitening product (Javex) but be careful when mixing the two: mini-explosion and spray will happen! Full protection is needed (suit, face mask/respirator, heavy rubber boots/gloves and do all of it outside in a empty space. The spray could damage other objects near by. Good luck.
Fantastic! Thanks so much. I will give it a shot.
