I bought some Amaco brand air-dry clay because I could find it locally and cheap, but the only information I can find online regarding it's sulfur cointent is Amaco stating that it's clays are all low sulfur. Will 'low sulfur' clay interfere with my Mold Max 30 silicone setting up? If so, can anyone reccomend an inexpensive clay I could get online that would be okay to use?
Also, are there any downsides to making a block mold and cutting it apart rather than going to all the trouble of making a two part mold?
And if I can lay one portion of my model flat, is there any reason why I should not simply do that, pour the silicone over it, and leave that as one big pour/air hole about 1" x 4" and then after cutting the mold down the sides so I can extract the models, pour into that hole until my resin is flush with the surface? (Think molding a shoe box witht he top open, and the bottom sitting on the base of your mold box, then flipping that mold over to pour the resin into the bottom. Except my box has a handle sticking out of the side, so I have to cut the mold in half so I can extract that.)
