Question for those that are familiar with coat and jacket making
Discussion in 'Replica Costumes' started by ssdesigner, Aug 19, 2015.
  1. ssdesigner
    ssdesigner Sr Member RPF PREMIUM MEMBER
    1,830
    I have a winter coat I'm looking at that is a size 42 Large.
    I wear a size 48 coat, what can be done with this? Should I alter it? Re-create the coat using the snaps/buttons and fabric info?
    -Ss
  2. ssdesigner
    1,830
    BUMP
    -Ss
  3. MaulWalker
    MaulWalker Sr Member
    1,241
    Couple of thoughts here
    Aside from the chest, how is the fit for the rest of the coat? Shoulders/upper back, torso length, sleeve length, diameter of the coat at the waist and hip? Those could drive your decision.
    When it comes to matching fabric colors, black is probably the hardest. If it is only the chest that needs to be larger, AND you can match the fabric, you could split the side seams and insert three inch wide (plus seam allowances) pieces of fabric. These would have to be tapered into the underarm seam as well. You would now have two "side" seams that would be somewhat hidden when your arms are at your sides. Tailored suit jackets are made this way. If you aren't trying to recreate this exactly, it might be easier to find a contrasting or complementary color.
    If it is more than just the chest measurement that needs adjustment, it would be easier to recreate the coat in the correct size.
    Unfortunately, it is very difficult to make things larger - it is much easier to make things smaller.
    Lynn
Share This Page
