Well, I promised a progress thread on my Vera replica build, so here goes:
I now have most of the parts I needed to collect together, before starting the real work (though I've done a bit...)
Here are the parts so far, just laid out on the floor in rough correlation to the prop layoat:
The flash hider is a Zprinter 650 RP 3d print (thanks to various members of the Sketchup & Shapeways forums for helping with the modelling, and West Wirral Works for the print...)
The D-Bal laser is a fake - a replica that is a actually a battery holder for airsoft. Needs some mods, specifically removing the actual battery case that makes it too large. Can't really complain for $25.
The larger scope is a TGS PV-14 that I'm going to mod to look more like the correct PVS-18.
Shells are Magtech 12 guauge shotshells. I have modelled the actual round, currently waiting for the mold to set before casting in resin.
I've repaired the broken stock, needs a lot of sanding down, and drilled out the holes in the stock that were filled for the stunt cast.
Started work on the top rail for the scopes (not pictured)
Hoping to get some decent progress over Xmas.
