Predator - P1 Bio - need help
Sorry I haven't been following you closer, this has definitely improved and is really close to a finished product. Dreads are not easy if you want the right look, and especially if you want them to move right. They have to be loose and have weight so they swing as the head does without looking like they're rigid. I found that purchasing them premade from someone that knows what they're doing worked for me. If you need a name let me know. Hope this is isn't dead in the water....
Hey thanks for taking the time to respond. It kind was put on the back burner. Part of me wants to hook in with wet -n-dry (start at 120 grit) and sand it smooth. The other part of me says best leave it alone.
I scored a mannequin a few weeks back and dressed it up with the Pred. He needs a neck seal and I had one that I wasn't using and gave away to someone. What was I thinking? Never mind.
So whilst not worthy of the Hunter's Lair, but I think he looks pretty neat.
attachment.php
In time, I will build all the armour using the same materials I used to build the Bio.
I am using that suit to build a back up Predator prop for my Halloween decor. I built him a cannon and am literally working on a spear for it tonight.
Paper mache Cannon...
I saw that on the What Is On Your Bench thread. I have some 60mm PVC pipe. I should make a cannon.
