Pepakura - tape and resin question
Fk23
I started to build a mask by one of your forum members, Fierfek. It's the Darth Revan mask. It's coming out okay so far ,it's my first. It's not as neat as I'd like to have made it but that's my own novice problem.
What I have got a query on is that some of the tabs, mostly on the inside, I've fastened tight with sellotape, during the glue drying (I have been using an off-brand Pritt Stick). Is this going to cause issue during the resin stage? Should I remove it all before that stage.
Also what are the recommended resin and fibre materials to use once I get to that stage? I'm in the UK so the brands may be different here!
maybe remove the tape so the resin can get to the tab on the inside and soak into instead of covering the tape in resin.
for materials,just look for "polyester resin" and "fiberglass mat" or "fiberglass cloth" any brand will do.
Thanks, I'll strip away the tape once the whole mask has been made up and try not to use any more in the meantime. I think I was just being impatient!
