Need help with removing material
AmazonChitlin
Hey all!
I'm working on a Kroenen mask, and I'm stuck. I can't figure out how to remove the material in between the nut and the inside edge of the surrounding part. I've included a picture sothat you can see what I mean. THe part really isn't large.
I'd rather not cut the part into pieces if I don't have to...
Thanks!
I'm not 100% sure what part you mean, but from your description I'd be thinking along the lines of a small hole saw maybe?
Whats it made of ?? & nice cat pic :)
you need a Dremel-type-tool with a small abrasive bit
I take it that the area you want to remove is this (in red):
Thanks Leigh! She's my baby, and I had to slip her in hte picture somehow. hahaha
I'm not sure I'd be able to find a hole saw that small, but I'll definitely look around. Most of the ones I've seen are all for larger holes.
Nobby, That is absolutely correct. Sorry I didn't make that clearer. I'll see if I can't find a bit out there today. By abrasive, do you mean something like this?
Those tapered bits don't tend to make a nice job of cutting section out IMO. I would use a straight bit like the #1187 in this pic
Just an update, I purchased the bits, and can't wait for them to get here.
Thanks again, guys!
