I want to put a single whit LED behind a diffused light panel button. I have a simple push for on/push for off switch I want to use. What do I need to make this work? I am thinking of parts from Radio Shack or some other easy place to get the stuff. Wire gauge, LED size, transistors [ yes/no - which one(s) ]. Everything. The switch and LED will be about two inches apart if that helps. I was also planning to rig up a piece of styrene with a hole and side shades to mount the LED in using 2 part epoxy and soldering the wires to the leads on the bottom of the LED sticking through the hole.
Can someone help me?
