Need help creating a Wayne Enterprises box label
paulv70
Anyone want to take a stab at this label?
Cool prop ! Could contain a few meters of memory cloth :love
Looks like the label is made of two distinct parts, each one having its own bar code.
You can see there's a small step between the two :
And looking closely at the screen still, it appears one of the two labels is applied onto the first one, partially covering it :
A bit like that :
Won't be the easiest thing in the world but seems doable :thumbsup
That's looks great! I'll make one up as soon as I can find that silver tape.
Thanks Dietrich!
FYI, the silver tape is waterproof aluminum ducting tape. Should be able to find rolls of it at Lowe's or Home Depot in the tape area...if you've never used it, it is rigid and will wrinkle very badly (as visible in the photos) when it is wrapped down over corners or not carfully stretched as it's applied. It's also quite expensive as tape goes...usually comes in really big rolls though. Other uses for your leftovers includes putting together TK helmets...I've used it for years to tape the seams from the inside...it's the only extremely rigid tape that stays put until you want it gone, at which point it removes (somewhat tough, but not impossible) with NO sticky residue on plastic. Love this stuff.
