Cgipperich
Hello all!
New user here, and I'll get it out of the way early and say that I'm very new to making art pieces so lamens terminology and heavy description is much appreciated =]
Anyway, I'm looking for advice on how to make a cast and several copies of a head bust I have created. We have a head created out of Sculpey and wish to make a solid reproduction of it that is light and durable enough to use on set for a film. For this same reason, we wish to be able to make several copies of it if the need arises. We also wish to be able to paint and decorate it. So I'm curious at the best overall process of doing this.
Here is the picture of the Sculpey bust we have created (not completely finished yet):
We plan on baking the head once it's finished so that it is hardened and more durable.
I've done a little research and found numerous ways of doing this reproduction with Alginate and Plaster of Paris but I'd like to avoid using Plaster because of the weight and brittleness of it. So if there is some sort of Silicone/Rubber material that would work better for our needs, I would like to know about that! And so far I've seen that Alginate has to be broken apart off of the mold, and therefore rendered useless, and hence cannot be done a second time. So we're looking to be able to make a single mold and use that to pour several heads if need be.
So the bottom line is: we need a reproduction process that can be duplicated easily and will yield: a solid head that exhibits the face we have formed on our Sculpey bust here, that is light and durable enough to be used on set, and can be painted and decorated.
Thanks so much!
- Corey
Thanks so much!
- Corey
