clonesix
Hi Folks, I got a DM from a new user who asked me the following question:
I have a question about mold making so here is my situation, if you have time to answer it
i will really appreciate it!
I just made a plasticine model about 55 inches heitgh, its a male torso with no arms (Barroque style)
I`ve made models and molds in order to cast be on resin (hard resin) before but he biggest that i`ve ever
got before it was 27inches the biggest.
Im at the "making" the mold part, by this moment i already applied the a thin layer of rubber on my model,
i know it as the "flow coat" wich is enough for the rubber to get the information from the model but not as thick
as the "later" coats.
Now i want to add the shim with basketball collectable cards (plastic ones).
How do think will be the best option to add the shim?
Should i mark where my divisions are going to be, and then make a thin cut on top of the rubber and place
the shim throught the rubber against the plasticine and then continue brushing the rubber to cover the shim?
My concern with this option is what if when i make the thin cuts on the silicon air gets filtered and affecting my mold?
or
Should i make a small stripe of rubber, attach it to the mold and then put the shim on top of that stripe and then continue brushing the rubber to cover the shim?
my concern about this option is mainly the materials, not spend that much of it if there is another way to do it
with less material.
The purpose of the piece its just an experiment, im planning to make a show and this is my first approach to it!
thank you so much for your time!
or
with less material.
