Scott, thanks! I could use sculpey for something I guess, I will work out my plans after I see DH Part 2 and get the full version of the castle on my mind and before I start school in the fall!
@cgraham, I was wondering what sort of materials you used to make your model of Hogsmeade Station.
and... cgraham, where do you keep the Hogwarts when it's not being displayed about town?
The buildings (and walkway bridge) are a mix of nearly ready to use models, kitbashed kits and modified models from Hornby and Bachmann (UK division). The station platform is 1" home insulation foam board with a masonite surface with styrene edging. The platform ramps are a type of tough modeling plaster. On each side of the station, I have sculpted terrain also from foam board.
After scratch-building Hogwarts in its entirety, I was eager to work with commercial kits and models for inclusion in the Station.
Hogwarts was built as a pair of 4' X 5' modules supported by rickety, bolt on/off 2"x2" legs. The buildings all lift off the mountain and are stored carefully wrapped in bubble wrap in plastic bins in my basement. Mount Hogwarts lifts off the base modules and is also stored in my basement. The Hogwarts modules are only 5" deep and are on their side against the wall in my garage carefully covered in plastic sheeting and movers' quilts. I'm designing a rig to stack the pair of 4' Station modules on top of each other with removable axel/wheels to allow me to move them like a hand cart in and out of shows. The stacking solution will also help with storage as they will effectively be "crated" for moving so the display surfaces will be protected from dust and being bumped during storage.
-Cgraham
