Re: MiB Orion's Belt (work in progress)
So, I've been thinking a bit about this project and since RP successfully had the galaxy printed with the cage-wires cast-in, I decided to see what I could do with that idea. Thanks in no small way to the fabulous photos Moffeaton posted above, I've been able to come up with this:
This is my latest revision of the piece. (I hope Moffeaton doesn't mind me borrowing his photo to compare.)The top "arms" have been shortened just a tad and the cage arms have been added. As you can see, the shape follows the large-scale hero almost exactly! (Note: the galaxy in the photo is lying slightly askew.)
I made it to take a 17-18mm marble but the thing I am most proud of is where it splits. the two halves of the frame are separated under the top ring. Each cage-wire goes into a small notch in the ring like this:
This will hopefully make the seam between the two halves almost invisible when printing in polished silver. All that should be required to assemble this version is a drop of superglue on a few of the "pegs" and the bond should be VERY durable if you want to wear it, just like the first version. I also made a couple extra notches as can be seen in the render but I'm not sure if I will keep them in the final design. I've ordered a couple test prints and should have them in less than three weeks. During that time I will look at the model and see if I've missed anything. The big drawbacks of these revisions is the added cost of printing due to the increased volume and that the margin for error is higher.
I'm also thinking of experimenting with a few marbles. To make it accurate to the large hero, it would be easiest to get a CLEAR glass marble and stipple on green paint with a stipple brush or sponge, then possibly clear coat it.
