klmscott12
I am looking to install the lights in my wifes Boushh helmet, but I am a bit dazed at how to go about this.
Heres what i would like to do.
Place two rows of 15-18 green LED's (one on top and one below).
Get the rows to blink on and off for 1 second each alternating.
Use 2-4 9v batteries (2 if possible) housed with in the helmet.
I have gone through the RPF site search on wiring LED's and found some good ideas, but none that cover blinking. I know that I will need to use resistors on the neg line and have been to the calculator site below and even tried a few things to get an idea of which parts might be needed.
http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng
Using the GURU option at the bottom I entered the following values;
Supply Voltage
18 VOLTS (for 2 9v batteries)
Voltage Drop Across LED
2.2 VOLTS
Desired LED Current
30 MILLIAMPS
How many leds connected
30
This resulted in a diagram of 3 rows of 8 and 1 row of six and suggested theses;
Calculated Limiting Resistor R1
13.33 OHMS
Nearest higher rated 10% resistor
15 Ohm
Calculated Resistor Wattage
0.01 WATTS
Safe pick is a resistor with power rating of
0.02 WATTS
Calculated Limiting Resistor R2
160 OHMS
180 Ohm
0.14 WATTS
0.24 WATTS
All of this I can wrap my head around (sort of), I just have no idea how or where to insert a "blinker". I am not looking for super bright lights, just something to complete the helmet. I have also looked at this for options
http://www.ledshoppe.com/Product/led/LE5033.htm
and would be willing to go this route if anyone knew of something closer to the screen cap above.
Any help on this would go a long way in making life smoother.
Thanks in advance,
Mike.
Supply Voltage
2.2 VOLTS
Desired LED Current
30 MILLIAMPS
30
13.33 OHMS
15 Ohm
0.01 WATTS
0.02 WATTS
160 OHMS
180 Ohm
0.14 WATTS
0.24 WATTS
Thanks in advance,
Mike.
