Here it is. The beginnings of CDR Cain's viper from Galactica Classic. This is the MIM ( Monsters In Motion ) resin kit.
I've gotten the fuselage sections pinned and glued. I'm in the process of fixing the underside by building it up so that all heights are uniform. I've removed all the molded-in T-channel and will be replacing it with Evergreen T.
If you look closely, you'll see the canopy frame has rivets in it. Those were done with white glue and a toothpick.
