dday
So the Masked Rider suit I ordered early this year has been sitting in my basement for a few weeks now, and I've been taking small trips down to look at it, but not been getting much done. However, as of yesterday and today, I changed that up and started doing things.
It is a bit overwhelming to get started on this thing. The kit is fully complete, comes with body belting to attach the parts, but this still take some work to attach the straps to the arms and legs, and the biggest piece of work I have is getting the connection between the thigh and shin pieces.
So I started working on getting the foot to actually fit my foot inside it. At delivered, the foot opening was too small, so a dremel and a few minutes later, viola!
After the first time testing the thigh, shin and boot, I had lots of chipped paint where the shin and boot came into contact, so I used this chips as a good point to put some soft side sticky velcro to pad up the boot some, to stop future gouging. I should have checked this first... no worries though. As this thing if fiberglass and paint, it's going to get some weathering and battle damage right out the door.
Once my foot was able to go in and out ( I still need to get some boots but that is for another moment) I was energized to work on the connection pieces.
First, I had to enlarge the opening for the knee on the top and bottom of the shin and thigh.
So I saw in a the build by MTCOOLJ http://www.therpf.com/f78/iron-man-mark-vi-maskedrider-armor-kit-pics-updated-06-25-2013-wip-185729/ that he got some thoughts and advice to use a metal bar, with a hinge in it.
I didn't want to use a flimsy piece, I wanted something that would hold pretty well some of the weight from the thigh and add some structural strength. Luckily I had some 20x2mm aluminum strip I've used in several other projects I could use for this. So I figured it's pretty simple, cut 4 pieces, make a hole in each end of all pieces, screw together win. Well, it was kind of like that, but not entirely.
So first step was to find a good mounting point for these new pieces. For the thigh, it was easy, there are the knee bolts that were easy enough to remove and drill a hold through and into the resin bolt as well to put a nice screw threw from the inside. Plus, the interior was pretty flush, so it was a piece of cake.
The lower end was a bit harder. I had to cut a dowel about 1cm thick then bondoed it down on the inside of the shin, pre drilled, since the angle is bad inside these pieces for a drill.
Now that all of the joints are sorted on the right leg, now it's to the left leg.... when I can get some time.
I put the entire leg and boot on and the movement was good, but it's hard to take a selfie with a SLR and actually getting a good shot of the leg, so the finished product you'll have to wait for.
More updates to come as I go.
