What type of clay is the sculpture done in? If it's a water based clay you'll need to fully seal it prior to molding with fiberglass of the resin will not set. The same with your dividing walls if you use water clay they need to be sealed with spray laquer then sealed again with PVA release. You will also need to do a gelcoat layer first because the laminating resin is not used for the first layer contacting the sculpture itself.
My suggestion is to take the advice of seasoned members and use a stone product. Fiberglassing a mold of 3 parts takes more work than I believe you're estimating.
Thanks for advice, i will be making gellcoat first and seal it. as for 3 part mold i have time. i know it will take it a lot of it. as for stone products i just cant afford them. in my country is weird that fiberglass and resign is cheaper then plaster
