fyreant
I understand that EVA foam suits are "throw away suits" once they get tore up enough, but I am curious as to what can be done to fix areas that have sustained damages to the finish. I made an Iron Man suit a few years ago, and wore it to a few events and now I have areas where the paint has flaked off and even some areas where it is worn all the way down to the foam again. I attached a picture to show an area that describes what I mean below.
How can one go about "covering up" this damage? This suit was originally done with the process of applying 6 coats of 50/50 Elmers glue to seal, 2 coats primer, 2 coats base paint, and 2 coats clear coat. I'd like to be able to restore it to better glory rather then just scrap the suit. Is there anything I can use to coat it and repaint it that would stick to the foam and also the remaining painted surfaces?
Thanks
Ant
Thanks
Ant
