Help Winnie Cooper become Wonder Woman!
Status
Not open for further replies.
I am sorry to hear about Mark. I've read through the comments for Mark, and the warm reflections garnered are exceptional.
My best to his family and yours.
-DM
Bloody hell... I've been checking in on this thread every now and again, but thats a true tragedy to hear about this guy Mark dying in a car accident.
Reminds me so much of Graham 'Vadermaker' Campbell dying tragically in similar circumstances all those years back :( RIP
And reminds me of how close I've come on more than one occaision :unsure
On a more positive note it looks like you guys are making great progress on the Wonderwoman costume :thumbsup
Cheers,
John
swdvds@yahoo.com
WOW!! Those turned out really Great! I hope you are able to complete everything in time for Halloween.
Sorry to hear about Mark Buck, I never new him but new of him from others...
Thank you for the kind words regarding Mark Buck. I just returned from his memorial service. As one colleague wrote, quoting "The Wizard of Oz":
"... a heart is not judged by how much you love, but by how much you are loved by others."
Judging from the turnout alone, Mark was well loved.
--Don
Okay, back to business...thanks for the chance to tell you about Mark.
Given the time constraints with which I had regarding the costume (my fault entirely--someday I will learn how to manage time), I tried something new--for me. I bought the fiberglass casting tape that physicians use to make casts. It's like a plaster bandage, but impregnated with resin, which can be activated by water...although I found that if you leave it out, it will set regardless, even if you try to re-wrap unused portions in plastic bags. I used the following methods because though I needed a plastic/fiberglass casting, I didn't have time to sculpt, mold, cast then clean-up the parts. However, it's a pretty challenging method, and probably is only best to use in certain circumstances.
Unfortunately, I didn't take any photos of the process, so you'll have to rely on my descriptions. Feel free to ask questions and I'll do my best to answer them.
The first thing I tackled was the bracelets (which I completely missed that they're supposed to be silver, by the way). I started out by cutting the toes off of a tube sock and stretching that over the arm casts, to act as a barrier and to give the final product some space between the casting and her arm. Next, I wrapped the casting tape over the sock, just like an arm cast would be made...I ended up making it about three layers thick. The tape sets in about 5 minutes, after which time I took a razor knife and simply sliced it straight down along the inside of the arm, cutting through both the tape and the sock.
Carefully spreading the opening, I pulled it off the arm cast and rough trimmed the length. After mixing up some auto body filler (Bondo), I spread it over the casting with a polypropylene spreader to smooth out the fiber texture. Once the Bondo set, I sanded it smooth and repeated that step several times, filling all the voids. I usually start out with 80 grit, and working my way up to 400 or 600, hitting it with filler primer along the way to check my progress and to help fill small voids and scratches. Getting closer to the final surface, I used spot putty to get small scratches and holes, until I was happy with the surface.
It's been a long day...I'll explain about the rest of the parts tomorrow.
--Don
I bought the fiberglass casting tape that physicians use to make casts. It's like a plaster bandage, but impregnated with resin, which can be activated by water... --Don
Wow! That sounds intriguing as Hell! If nothing else, it sounds like it would make mold jackets go a whole lot faster and more painlessly- Got a link?
Thanks! :):thumbsup
-Sarge
-Sarge
It's called Scotchcast Plus...I used the 3" wide (82003) variety. It probably would work for mold jackets, but it is somewhat thick, so you can't get it into tight spots, but it is much cleaner then the whole resin/fiberglass route...though they are quite expensive.
Here's a supplier, though not the one I used.
--Don
Returning to the discussion...
For the belt, I first determined the shape and position of the belt by taking gaffer's tape and mocking it up. I started by finding the center of the body cast (using the navel as a reference point), then taping strips onto and around the waist. I then sketched out the shape directly onto the tape with a sharpie, then pulled the tape off and trimmed it to that line. I folded it on my center line and traced the other side to make it symmetrical.
Once I had this best guess template, I took a photo of it in roughly the position that the artwork was in, then brought it into Photoshop and composited the belt artwork over my guess. After several modifications, I was ready to lay on the casting tape. Like the arms, I wrapped the waist with up to 3 layers of casting tape, but I did not use any barrier, as the tape didn't stick to the urethane foam body form.
After the tape cured, I split the belt in the back, and then layed the tape template on the inside of the casting--I did this because the thickness of the casting tape layers distorted the template. After tracing the template shape onto the casting, I trimmed it to size with a dremel.
As I did with the bracelets, I spread Bondo ove the casting and sanded it down to remove the cloth texture. To create the seam line down the center, I made sure the edges of the casting were smooth and used a compass to draw a line. Finessing the line with a ruler and my eye, I then took the smallest masking tape I could get-1/8 inch-and layed it down, making sure it was clean and smooth. I took more bondo and spread it over the tape, making that layer about as thick as the tape. Once the Bondo set, I removed the tape and had an 1/8" valley. Once I smoothed the belt further, I took some spot putty and filled the valley, and then just after the putty kicked, I took a nail with the correct diameter and dragged it through the putty, using one of the edges created by the tape. This gave me the correct thickness for the groove.
Finally, I continued with smoothing and sanding until I "sculpted" the piece to my satisfaction, using the same techniques as I described with the bracelets.
I'll finish the description later...
--Don
Better line those gauntlets with material to prevent sore wrists.
Outstanding work don she is going to look great in this.
Just as well it will keep everyones eyes away from mike falling about and bumping into things in his costume....if your planning on drinking alot mike make sure you have a built in easy access flap ;) :p
No, we're not done, and won't be. Don and Anna lost a very close friend, and we're not going to pressure them to do a costume right now. It's just not that important. They went to Mark's wake just this past Saturday! In any case, Mark was doing the Iron Man suit, and so obviously that didn't happen. All in all, our plan is to finish them as soon as it's reasonable - I mean, we're awfully far along anyway, but we both felt strongly that the respectful thing to do was give them space right now.
_Mike
We didn't exactly have back-ups planned, so we're going to sit it out this year. Sometimes, that's the vibe.
_Mike
Sorry it didn't work out Mike. It'll be great next time though. :) You're doing the right thing not worrying Don during this difficult time for him. I know he'll appreciate that approach. Peace,
Dave :)
Mike,
Great to see someone with their priorities straight. Props, costumes, the hobby stuff - it gets built up to be much too big in people's heads around here. Here's to a kickass duo next Halloween...
- Douglas
We had dinner at a place a couple of weeks ago with our friends Dan Lauria (who played the Dad) and Alley Mills (who played the Mom)...
...it was pretty funny watching the waitstaff do triple and quadruple takes, I have to admit.
_Mike
Thats really cool Mike. Its been fun watching the costume come together, and I suppose that with a whole year to play around with it you two will have a great Halloween next year!
~Bobby
_Mike
I'm sorry you won't be going this year.. That's extremely good of you and
Danica for thinking of them first..
Well you could always go as a grown up Kevin Arnold, and Winnie Cooper :)
That wouldn't be too hard to pull off, You've already got Winnie, and the Dark
Hair to play Kevin.. That would be frigin Classic!
Status
