AnubisGuard
I have a set of 29th century tricorder electronics from gmprops that I'm waiting to permanently install (once I paint the body) and lately the third of the four green chaser LEDs on the left hand side - the ones under the "ALPHA BETA GAMMA DELTA" graphics - has intermittently stopped working. It was fine for the first couple weeks I was fiddling with the board, but lately more and more frequently the board powers on with that LED dark, until I shake or hit the tricorder body. This suggests a loose connection, and indeed one side of the LED appeared poorly soldered; I added more solder last week but, after initially seeming to fix it, today it's started doing it again. I re-resoldered the connections to no avail, and am at this point worried about making things worse.
I'm not skilled with electronics, so I'm not sure how else to diagnose it. The solder joints look fine to me now; could the LED itself be bad? Is there a way to repair it without having to remove and replace it?
