there was somebody who cut the nacelle off and fixed the issue. However my own stopped workign after about 6 months. I frequerntly (as often as I could remember) would turn on the power and apply a hand massager that vibrated onto the nacelle and body arond the housing where the moro "must be". After MANY failed attepmts one day it stated to spin again. I know run it for a minimum of 1/2 3 times a week. and its been running since.
I just went back and checked it was July... probably a hot day, perhaps that had something to do with it as well... maybe a bit of heat from a hair dryer along wit hthe vibration might be the trick...
I was very persistent. it took months for it to start back up... but it did. I would try applying gentle heat (hair dryer) and the vibration while tunring it on and off...
but if you're bound and determinded there was a guy who did it and recorded how.
Me too. After about a year or so in storage I brought it out and one nacelle motor stuck. I was bummed! But I left the switch on and after about 2 hours it started up! Been running fine ever since...
