Halo Reach Brute Spiker
Strode
Hi guys,
I always wanted to build this gun.
Something about giant illogical blades attached to rifles which fire hot spikes really does it for me. Also I needed a break from my other more-or-less-always-incomplete projects so I decided to start another one I will probably never finish. Anyway, onwards!
I decided to build the Halo Reach version cause it had the best references in terms of multi-angle shots. These shots allowed me to draw up a bunch of blueprints that I printed out, transferred them onto 2mm PVC sheets and then cut them by hand.
Once I got the main blueprints marked out, I started to put it together. Apologies for the crap pictures, I have a camera phone and I work mostly at night after work.
Barrel parts
Barrel internals
Lower body round thing parts
Upper main body parts
Test fit. By this time I had filled in the main body with Plaster of Paris and epoxied two threaded bolts to hold the barrel securely to the body. I still haven't decided whether this was a good move or an extremely stupid one :/
Lower round thing, I used aluminum from a beer can to round it out...
Here is a dry fit of all the parts so far. I had a PVC pipe lying around that fortunately were perfect for the barrels. I also filled the upper body with more Plaster of Paris, and sanded it down to make the contour.
I cut the pieces for the side plates of the barrels and attached them.
By this time, I decided to add light to this thing. Brilliant idea but I've never added LEDs to anything before or worked with electronics ever. Also, I never designed it to have space for a battery. Joy. But anyway, after some reading, questioning and not burning my house down, I managed to light 5 LEDs. Honestly, it was a big moment for me, because I have never done anything like this before.
I moved on to the sights on top of the upper body. The black stuff is plumber's putty and the amount used is a testament to my skills :/
Added more putty to the barrel side plates and those things that go on them.
I then moved on to the upper body shroud. I measured and cut everything and the thing still turned out too small. So I sliced it through the middle and added more putty to make it fit. I used auto body filler and sanded it to make it smooth.
The lower round thing was a bit more complicated. I only have 2mm and 3mm PVC sheets on hand. This lower round thing had to have channels. So I measured out a piece of 2mm PVC sheet and sanded it tediously down to what I hoped would be 1mm and cut the channels in. I then rolled it over the round thingy and added more putty to blend it in. Everything was sanded smooth later.
Started on the barrel. Added more plumber's putty and bondo to get a bit of thickness.
Then I tried to complete the barrel, adding the upper and lower parts. Lots of bad fit. Lots of bondo and sanding :/
Unfortunately, it seems after this point, I worked on all the little bits and bobs but I failed to take pictures. The angular stuff that holds the blades were quite fun to do and I'm glad they worked out cause I had nothing more complicated than a cutting knife and a ruler. Both blades are pointing in the same direction and have the exact angle so that's awesome.
I used a hacksaw blade and cut the blades out of 2mm acrylic sheets I had lying around. Including the tiny little blade at the bottom of the handle. I added more detail pieces and filled in all the gaps. I couldn't resist putting it together at this point to see where I was.
Lot's of sanding left to do at this point. Many bits and bobs still missing. A LOT of filling and work left.
After tons of sanding, filling, more sanding, filling and days filled with bits and bobs, all of which I've forgotten to take a picture of, this is where I am now. it's held together by friction hence the tape and the bad angles.
All the reference pictures I have indicates this gun is treated very badly. Lot's of scratches, cracks and scars so I didn't concentrate on getting the parts perfectly smooth. Especially the harder to reach places. Mostly cause I was lazy and couldn't be bothered and it fit the story perfectly. There's lots of work left but I'm close to finishing it.
Now I am a bit confused. I'm wondering whether to paint it up as is or should I cast it. I've never casted anything before so that's a bit daunting. If I do want to cast it later, can I cast it after paint? Thoughts guys?
Hope you liked it so far.
That looks awesome! I've always had a Playstation, so I missed the whole Halo franchise. I always enjoy seeing new weapons from the series.
Thanks for sharing your build progress. Looking forward to seeing it completed.
I can't wait to see it done! Wow I just can't believe it. :eek
~ I Athena I
Thanks guys. Paints are coming tomorrow. Never painted anything before so this should be fun :)
