Gremlin Vinyl Kit Thialand
Jodd
Yesterday, I saw an Ebay auction for a Gremlin Vinyl Kit that is shipped from Thialand, but the vinyl is hollow from the inside. I guess I will have to add some type of foam to make the item more sturdy, but I am still deciding if I should wait or buy the item.
More than likely it is a recast off of the one from a few years ago. Vinyl kits are usually hollow.
If you fill the feet with concrete, that should be more than enough to help it stand, although, you could probably build it without.
I'm, also, going to guess it could be a recast. Usually, these Thailand kits are bad. Steer away.
You'll end up potentially wasting as much money as it would cost to buy an original. It may take longer to find one... but the quality is so much better and you'll not support recaster leeches.
Thanks for your help, I have decided to wait. The seller has a good feedback rating, but I would rather buy quality replicas.
i Have been trying to track down a non recast stripe kit for awhile now. Good Luck on your endeavors. and if you hit upon two drop me a line. i'll do the same.
A Thai kit producer with good feedback? He must be having other Thai recasters shill bidding his stuff to build his rep!:lol
