Ghostbusters part identification help
AZspidey
I have all the other parts figured out, I just cant seem to figure out what the white box with the slits on the side is. I put a red box around the piece so you know what I am talking about.
-Todd
Not Clearly.
look at it, components stuck in it, the end of the ribbon cable is plugged into it just like how the other end is plugged into the other breadboard.
You can push or glue components onto anything, so it doesnt necessarily mean its a breadboard. You can tell its not the same because it has 4 grooves or slits down the length of it. I have never seen a breadboard like that before. Here is another pic where you can kinda see it better.
AZspidey, since you live in AZ you may want to check out Apache Reclamation if you have not heard of it already. AR is an electronics junkyard. I went there for stuff since '85. I was able to find many GB parts there. They had(bought them out) a crapload of the vintage engraved TOS phaser dials as well. I don't know if they have the part you are looking for in this thread but it's a cool place to check out on a weekend. They have the 2 front rooms and the huge back room. Then there is the lot outside as well. Not the kind of place that you can call and as if they have what you need. More of a see what they have.
313 W Apache Street, Phoenix, AZ 85003
(602) 254-0613
(602) 254-0613
I heard they closed down a few years ago?
[snip]You can tell its not the same because it has 4 grooves or slits down the length of it. I have never seen a breadboard like that before.[/snip]
Thanks because it's just 4 of the 2 wide boards held together by the ribbon cable contacts.
I have a couple of large projects on the workbench so I only have 2 available to take pics of.
attachment.php
attachment.php
