What were the ratios of paint to podge that you used?I've recently painted my foam project with a mixure of acrylic paint and Mod Podge I got at the local art supply store. It was an experiment that turned out well.
What makes this especially nice was I was able to wet sand errors, runs, etc. and repaint.
mix a little liquid latex in to acrylic paint. (or anything water-based)
up to 15% by volume should do. this will make your paint more fexible and keep it from flaking and help it stick to the foam a bit better.
Can't wait to see what you come up with.
This is similar to using Flexbond.
Flexbond is part latex, part glue... which makes it perfect for sealing foam - it improves the bond between paint and foam and makes sure the paint is flexible.
Well what a disappointing day off, I went to get more EVA foam from local supplier and they have shut down and nearest outlet is 100+ kilometers away! Checked a few paint stores and no luck from any of them with any vinyl paint or Kryon or Flexbond, the people who work at these stores looked at me like I was odd for suggesting a paint that might flex without flaking :S
Latex paint works fine. Just how much stretching are you planning here?
Is the flexbond mixed into the acrylic paint prior to application onto the foam?
Would this be a better alternative to PAX paint? (PAX paint = pros-aide and liquitex)
FYI Rinzler and I are pretty much working on the same project. I've been hovering most Tron related threads.
@Rinzler - google PAX paint. I've been trying to do research on it recently...
Have you tried floral spray paint? Most craft stores have it and it comes in a variety of colors. I've used it to paint lycra before and it stretched with the fabric and was very flexible. Might be worth a try.
Fullmetalsam,
I was thinking of mixing Flex with Liquitex 1:1 and some thinner. The paint will be strictly Black and it will be painted on black(dark grey) closed-cell foam. Do you think one or two coats of this slightly thinned paint will result in a streaky/thicker paint? Thanks
