tim
I also posted an extended work-in-progress thread at COW, but summarize below.
I wanted to build from scratch one of the small beacons that we see Mac leaving behind so that Spalko could tail him and Indy as they searched for Akator. I also wanted to make mine blink like the hero prop in the movie.
I purchased some plastic domes (for panel indicator lamps) and high-brightness blinking red LEDs with built-in IC.
I mounted an LED on a scrap of perf-board with a current limiting resistor in series. The completed circuit was then epoxied inside the dome. I decided to use two silver oxide button cells to power the device; these resulted in good brightness and a blink rate of about 1.5 Hz. I next found some half-inch copper coupling at Home Depot, cut a piece to length, and painted it silver.
I used a piece of 5/8-inch oak dowel to form the tail section and battery cap.
Finally, after puttying, sanding, and painting the oak tail section, I added an o-ring to complete the prop replica. I estimate the result to be 90%-95% screen accurate, which I think is pretty good for my first scratch-built prop replica attempt. :cool
