Hemble
Hi All,
Recipe.
AT-ST & figures- is from Bandai and has been built straight out of the box. The figures are from the Imperial Assualt box set and the troopers are been modified.
Base - is high density foam and cut out and the trees have been done by using aluminium foil and then spakfilla was used to cover the foil and a wide brush was used to make the bark. The branches are from Woodland Scenics, I also used woodland Scenics for the smaller trees.
The ground work is spakfilla mixed with dirt and then spread across the base and once dry I used a mix of static grass, ground up leaves, dirt, railway model foam clumps and blended the lot together and glued to the base. The mud is a mix of spakfilla and paint and it was dapped over the base and once dry I used Woodland Scenics Realistic Water to give it a more wet look.
The undergrowth is from a company called MiniNatur and also Army Painter and once applied to the base it was sprayed with Matt Sealant.
Ron
Recipe.
Ron
