Dark Apparatus project: Real Parts Sleuths, please take a look
That is a great catch on the motor stators, once you look at it that way it's hard to imagine them being anything else :thumbsup
...Updated dimensions thanks to egosheep's eagle eye on blueprint measurements. I till need to work out the lock assembly from references (and key of course), but got the case and a bit of hardware in, matched to the prop's specs. Not great renders but you get the idea...
...I still need to work out the lock assembly from references (and key of course)...
I bought a couple of keys that were the right style, but found that this one seemed to be the right size. It needs to be plated silver/nickel (or stripped to the base metal if you want to go to the trouble). There are a couple matching half-mortise locks as well that the key fits in, though I don't know for sure if they match the one in the prop.
https://www.mediafire.com/convkey/58a6/u8367gro6lye0b44g.jpg
https://www.mediafire.com/convkey/7a27/fb9ahs0f8230ddp4g.jpg
Can't believe the progress you have made in just a few weeks, it's awesome to behold! The handle model looks great! I checked a bunch of hardware places and did endless searches, it's real but it's so hard to find.
Here's a 4K of the key. Looks like a good match.
There are some half mortise locks on the same site that use that key, one might be close enough. I can put up some detail shots of the lock.
https://www.paxtonhardware.com/product/jewelry-box-locks
That's just epic.
I'm getting the left side ammeters tomorrow I hope, so I will have another hard number to add to the model!
Ego, if you can get the graphic files for the top decorative plate, I’d love to take a crack at throwing it to my laser. I’d be happy to help you guys out, but creating the graphic files definitely isn’t my specialty.
That sounds amazing! PM sent.
...Still chipping away, looks like a bit will have to be winged for the deep internals until we get better references.
Gearing corrected and other hardware added
laellee, you are killing it with this. :cool I only wish there was some way I could help! What about wood box construction, could we get on track to start those in a few months?
Edit: I also have the correct Samsonite in hand, I could send you those internal dimensions if you want to model the interior blocking structure of the suitcase.
Yep, that would work :) I'll take a look tomorrow, but I think my box dimensions have been adjusted to your blueprints. I'll double-check the hinge dimensions as well, but it shouldn't be tough for me to work up construction schematics with the correct mortise dimensions.
