I've been making some good progress on the dome arm mechanism this week. The mech was designed so that I can create a cross beam from aluminium extrusions I have from the local hardware store. After measuring the up extrusions, I modelled them in Inventor so that I could design the beam.
I have to all this with hand saws as I don't have a lot of room for tools in my home workshop for stuff like this. First, I chopped a flat bar and right angle to length, so they'd fit nicely within the dome:
I then keyed up the surfaces of the flat bar and angles with sandpaper so I could glue them together:
After which I needed a bracket that would allow me to connect the beam to the 3D print. Essentially once I have the top plate cut and glued to the dome I can simply slot in the cross beam on the inside and then this bracket will hold the beam up against the underside of the top plate.
This way the entire dome arm mechanism can modular and removable if needed. I also designed my 3D printed dome to include embed M6 nuts so that I could simply use a bolt to connect the bracket. So that the bracket could fit in between the sides of the cross beam I had to trim back the overall width of the bracket. I just used my hacksaw for this, you can see the difference below:
And then this is that bracket installed in the dome:
With the bracket installed you can see how the aluminium cross beam I've made slots nicely into the opening of the print and around the bracket:
Next I needed to cut some openings in the cop of the cross beam to allow some extra head room for the linear actuators to retract. I simply drilled some holes and around the perimeter of my marked out area and then used a mini hacksaw to cut the remaining connecting material. After which the beam was placed in my vice and the inner edges filed down smooth.
