BSG Pylon vessel (Battery ship)My 1st scratch build DONE
cylon75
HI . This is going to be my 1st attempt at a scratch build the Tubed ship( or as giftworks calls it the battery ship).I'm doing it to add to my fleet don't really know the real scale will be but it will be around 3 1/2" long when done. I just finished a template that i did to work off of ,and there aint a whole lot to go by so some of it will be my interruption we'll see how it comes out .I just ordered some rod stock so I'm going to do the platform 1st because i believe that i have enough stock to start that.
Screen shots of the ship:
template:
Re: BSG Tubed vessel (Battery ship)
Cool! :cool
So what's that lifting body looking ship, approaching it?
The cylinders look very very close to the shape of pulse rifle grenades with the caps off. Would make sense with the Sullaco in tow.
Well so far so good. I glued 2 pc of 1/16 flat stock together to make the base .When i studied the picture of the ship it looked as if the area that the silos sit on are raised so i added another layer to that to.I'm gluing the center pc together now so this will be it for today.
Today i worked on the center pc and the engine pod. There not done but taken shape.
Thanks to a friend on galactica.com that sent me some very nice files on this ship i am now able to make it better, i redid the centerpiece which was way easier to see on his files .( thanks Andrew)
I worked on the head this afternoon But i think I'm going to re due the top notch its to deep for my liking. I also added some little pieces to the engine pod i didn't like it smooth looking it didn't look right. It also looks like the length will end up being 3 1/4" long
Re: BSG Pylon vessel (Battery ship)My 1st scratch build
Well this is it for now until i get in my rod stock in .Today i redid the engine section tweaked the headpiece and made the base plate piece a lot more symmetrical .
Today progress:
My rod stock came in today here's my 1st pylon 90% done, the height looks about right .I was going to drill out the base plate and slide the pylons though but that's not going to work as i thought so it will be a lot easier to glue them in place one by one.
Well i had a small set back ,i messed up the base plate when drilling it to try to attach the pylons so i went back to the drawing board and redid the base plate taking time to measure and double check the template. (the drilling idea has been caned ) I want it to be as nice as possible if it has a chance to get casted. I'm redoing the head and engine pod while I'm at it and it is a little bit longer at about 3 5/8 " here's pictures of what i redid today.
OK here's the new head and engine pieces ,They are a little bigger and look more to scale with the rest of the model. The new overall length is 3.5".I just glued the little pieces of pylon on the bottom of the base plate so now it has to dry for a couple hours more photos will be coming later.
OK this is what i will turn into the caster (except for a little clean up) I added a little detail here and there to give it a better look. I hope you guys like it.
Underside:
OK , i got another small idea along with the 4 small thrusters on the under side when i went to bed last night for the engine pod and i like it .This thread will be inactive for a little bit as i sent it to be casted this morning . The way you see it here is what the kit will look like.
That is just tHe AWesome!1!! :thumbsup
Now I am most definitely moist with anticpations and quivering.... :shock:
:p
Just tell us when, how much and where to send the money!
:thumbsup
I got good news this will be available as a kit from starship modeler in the near future.
The caster has posted pictures of his casting of the model on RI at the link provided.( if your not registered you will have to ,to access the link -but you wont be sorry)
photos link
The cast came in today and i got it all together fairly simple. You will have to use a compass to make 1/2" circles (see picture) on the face of the base plate to no where to put the pylons for gluing and cut the pylons down to 13/16 from the top of the big pylon to the bottom (See picture) And make sure you glue the spine on the right way ( angle notch is engine end). I made a dumb mistake and didn't soak the pieces first so I'm doing it now so i can get all of the release agent off to paint it.
Well its primed and a couple coats of paint. weathering & detailing to night if the paint is dry .( it was still tacky this morning, my basement must be a little cold)
