Brush on primer?
_Lee_
Guys,
Do you have to use spray primer on props? I was thinking of doing a large prop primer application using brush on /tinned primer and then sanding to a finish-is this a waste of time?
Lee
Typically spray can primers apply more even and are a lot tougher. Plus you don't have to deal with brush strokes so no real sanding is necessary.
That being said, I have experimented and had good luck with Rust-Oleum's Brush On Filler Primer. (This one) --> http://www.rustoleum.com/product-catalog/consumer-brands/auto/primers/filler-primer-brush
Comparing the two, I personally prefer spray cans to brush on primers just due to the ease in application, but as far as the finished results? I didn't really pick up on any huge differences. If you get a good application technique down you won't even notice the difference.
Thanks chaps. Still learning as you can see :) im just hoping i use the correct primer that i can spray onto after :)
