Batman and running face paint issues
Meathead316
Hi
After wearing my batsuit for around 20 mins my black eye makeup begins to run due to me sweating, any way to prevent my face paint from doing this?
I use snazaroo black water based paint
Also my Joker friend has a similar problem, he uses same brand paint for black and white, and red lipstick, any way to make his face not smudge should batman want to put him in a headlock?!
Thanks
Well, first off, I would suggest using makeup not paint. Its designed to stay on under those conditions. Try grease paint if that is not an option. Anything but a water based paint would probably be better. Sweat, is after all, water.
8 perf is right. You want to be using actual makeup. Yes, it may feel weird applying makeup as a guy, but just remember that Christian Bale and Heath Ledger both wore it and you'll be fine!
I recommend Ben Nye. They are pretty affordable, widely known/used, and a performance industry favorite.
I use the eye black professional athletes use with an application of Ben nye setting powder. Never have I had an issue and have gone as long as 8 hours
Pick up some black eyeshadow dude, sugarpill eyeshadow will stick forever and is the darkest you can get
For batman I use makeup called scandaleyes that has worked great. It doesn't look too shiny, instead it'll be a more matted finish
