Anything thinner than glazing putty?
Risu
I've been building up a piece that I'm working on, first with foam and styrene, then with bondo, and now trying to get a smooth finish with glazing putty, but no matter how many times I go over it with the putty, I keep getting little pock marks and pits all over the surface. Is there anything thinner than glazing putty that I can fill those spaces in with and smooth out the surface?
If I go with that I'll have to be really careful about masking certain parts so that they don't lose detail. What's a good brand/place to buy it?
auto parts store sell it. But, have you been applying the glazing putty with a razor blade? That way you can apply it in a controlled manner just like wall spackle.
Spot putty is meant for filling pin holes and very small imperfections.
I use the green version from 3M.
3M
It doesn't use a hardener. It is air dried.
See if you have a finishmaster in your area.
They are a supplier to the auto body industry.
SEM makes a really good high build primer spray can
that you can get there.
I've been using the air-dry glazing putty and applying it with an old driver's license. It's worked pretty well for the most part, except parts of the putty I guess are leaving air bubbles and recesses inside when they harden which are exposed again when I sand it smooth. The resulting surface looks like this no matter how many coats I put on.
I'll keep that in mind to speed up the process on the angled section. The filler primer is working pretty well, despite some of the really large pits, a couple coats filled in mostly everything. After I sand it later tonight I should only need one more coat of the primer and the sides will be done. Thanks for the advice everybody.
