Hi,
I've decided that I've been lurking around here long enough and that it's time I contributed more than the occassional "Wow" or "that's brilliant".
I recently got hold of a Rubies Vader mask and have been correcting the inaccuracies in the mask and helmet. I'm aming for a look that's mostly ESB.
My original idea was to use something like apoxy sculpt to simply work on the existing piece but the more I worked, the more I realised it would be better to simply use the original as a plug and then cast myself a new piece our of resin.
I've had to cut away quite a bit of the existing mask and sculpt over the top using clay to produce a master to make a mould from. Since I generally work quite slowly on things like this I chose to use Klean Klay - an oil base, sulphur free product that doesn't set. I can therefore simply scrape off the clay when I do something wrong.
I have so far...
Cut away the existing eyes and rebuilt them.
Cut out the bridge of the nose and built a new one(I did this forst and uised Milliput here).
I've removed the internal nose plug and resculpted the front of the nose.
For some reason, this Vader looks almost as if he's had a minor stroke - the entire right (as you look at it) side of the face is sort of 'slumped'. I have spend quite a bit of time building up the right cheek so it's level with the left one and then re-working the curve where the mouth meets the cheek. I have then had to push out the side of both cheeks a tad and make new upper side tubes.
The mouth holes (slots?) had to be squared off since the ends on the Rubies are rounded. They also need lengthening a bit (still to do).
I warmed the neck area and reset it to reduce the neck flare and have completely rebuilt the ridge over the top of the helmet to make it slimmer and less rounded. I also took the opportunity to rework the frown lines on the front of the helmet and crispen up the line were the curved part of the helmet meets the flat part.
Here's a few pictures of where things stand at the moment.
The silvery stuff behind the eyes is from an old LCD monitor. It's not the final lens material, just something to hid the support for the photos.
As you can see, there's still a long way to go but I'm enjoying every step of the journey.
I have so far...
