majenko
Member
It runs off anything from about 4v up to 9v, so the world is your mollusc of choice.Well, let's do this thing. Oh, what type of battery options are you looking at?
3.3v, but for more powerful LEDs you should really add a transistor to run them as it can't provide much current.Ha, when I get my PR in two weeks do you need a Beta tester!?!?! :love
For the pads for LEDs what would the output voltage be?
Ouch, that's meaty. What did you drive it with?On my PR that I had I used a 3watt white Luxeon in the barrel and a red/amber K2 in the GL barrel.
That certainly would be funky. If it's to light up at the same time as the barrel tip LED, then no extra coding would be needed, it could just share the same feed. If you wanted it to be more of a pulse of say 3 LEDs lighting in sequence, that could certainly be done. Not sure if it should make the "default" firmware though. A good add-on idea though.Hopefully the following meets with better approval.
Why not multiple colored or plain white LEDS in the shroud that covers the barrel?
Placed so they cannot be seen, behind each metal grate/vertical support.
If you watch the movie, when the pr fire it lights up a bit due to the muzzle flash.
ONE led in the barrel tip that you cant even see if you are holding it, just does not seam to do it justice.
Well, that would be interesting, having remaining shells displayed on the counter. So, insert mag and counter goes to "95", rack the pump and it shows, for example, "5". Pull GL trigger and counter goes to "4". Pull PR trigger and display switches to "95" and counts down as normal. Cycle the pump and display goes back to show "4" for remaining shells. If you can program that, it would be pretty cool.
I am considering a website that will let the customer automatically generate their own version of the firmware with specific options turned on/off, or with specific settings - even allowing them to upload and convert their own samples.I'm no computer programmer by any means and that is why I suggested the "Options" list of special programming for the customers needs. Have a base set up with base features. Then list what the customer can have changed in the programming when they go to make a purchase. What to add or take away would be something you would have to come with as the programmer doing the work.
Probably not until after the new year (chinese) as I doubt I can get the new boards made before then. Especially if I'm redesigning the expansion port area to give 5 transistors (or maybe a ULN2003 if it's smaller).Good deal then. I can't think of anything else to add then. I'm sold. So when can we expect to see this going up for sale?
