I just received two rolls of Hobbyking Flexible Filament. It's much cheaper than Ninjaflex, but maybe not quite as flexible. However, the flexibility is perfect for something like a uniform shoulder patch. I bought both translucent (colorless) and black filament with the idea of switching filaments halfway through the print to make a 2-color patch with a "silvery" (translucent, possibly painted silver on the backside) backdrop and black top layers.
My very first test cube printed out fine. I'm using a Wanhao i3 with the Flexion extruder. I decided to do a full size SHIELD patch and just let the whole thing print with the translucent filament. Using red Ninjaflex, I had noticed that Ninjaflex paints kind of OK and can also be painted with black permanent marker.
The translucent print came out fine (I might try a slighty higher extrusion multiplier, but it was close enough), so I then painted the raised black parts with a permanent marker. The Hobbyking filament took the permanent marker really nicely. Here's a photo of the result. Remember: the raised black parts are hand-painted with a cheap permanent marker from Lidl...
The print temperature for this filament is 200°C-210°C (I used 210°C), so if your printer can feed flexible filaments and normally prints PLA, it can print this stuff too. I didn't even use the heated bed. The print stuck to the bed just nicely (the Ninjaflex version was actually very difficult to pull from the Buildtak).
